Hey everyone,
As of leaving the mechanics 2 weeks ago, he tested the long and short fuel trims and both were in normal range. However that was 2 weeks ago and they have not been tested again since then.
The photo above shows what I saw when I pulled the spark plug in cylinder 4 today to check, after having driven it for the past 2 weeks since the repair and was happy to see the electrode and ground are not fouled and color seems normal. However as you can tell from the photo the tip of the ground appears chipped! (And it certainly wasn’t when we first installed it.) There also appears to be some carbon towards the bottom of the ground. Is this normal? The wet stuff on the threads is anti-seize by the way.
We put OEM motorcraft pre gapped spark plugs so heat rating or improper plug/gapping isn’t an issue. If you were me, would you replace the plug since it’s slightly chipped? Because…
Even after this repair, when I’m accelerating hard it will SOMETIMES hesitate just a little bit. (Does not do this everytime). The car is running 90% better after doing the repair 2 weeks ago, but especially under load, I can tell it’s still not 100% right. Again, only sometimes! Most of the time it will accelerate normally even when doing a hard pull. The times that it does have the hesitation, the best way I can describe it is I’ll floor it, the car sounds like it does when you’re hitting the rev limiter in park and it won’t rev any higher. Only it sounds like this WHILE accelerating. It basically sounds and feels like it’s bouncing off the rev limiter for a couple seconds while it’s speeding up before it downshifts and returns to normal. Not sure if I’d even call it a misfire, maybe for lack of a better word…on a scale of 1-10 on how bogged down the engine feels when it does have this issue, I’d say it’s a 2.5 or 3. Very minor but something still not right. Given the plugs aren’t fouling anymore just from a visual inspection, I’m not sure if this is happening due to the chipped plug. Also what would cause a chipped plug in the first place? Due to the plugs not fouling after 2 weeks, I think it’s safe to say the fuel trims being correct now but then why am I still getting this annoying intermittent hesitation under load?
Another thing to note is the mechanic had to use a different brand of spark plug wire he had lying around for just one of the wires because one of them broke when he was taking them off to put on the new plugs. The wire was the correct length for the respective cylinder and was new, it was just a different brand than the other 5…this shouldn’t make a difference should it?
All of the following have been replaced in the past 2 months:
IMRC actuator (the entire unit itself is brand new), one bushing on the actuator that somehow broke off despite it being a month old, fuel filter, fuel injectors for drivers side bank, MAF sensor, air filter, all o2 sensors replaced, TPS, EGR valve, throttle body cable, fuel pressure regulator, coil pack, OEM wires and plugs, ran bottle of cataclean through gas tank.
No codes before or after the repair
