Can anyone please tell me the name of this parts?
It would help to know the make, model, and year of the car and the location of the part on the car.
Ed B.
year 1995 toyota camry sedan 4doors 3.0L , i removed it from transmission
Neutral safety switch…aka…Manual lever position sensor
It’s the switch that knows if it’s in park, reverse, neutral, or any of the forward drive gears.
The switch that turns on your back up lights.
Why did you take it off ?
What problem are you attempting to fix ?
thank you
It has a wire plugged into it on the right side, correct? It looks like some kind of position reporting switch, with it going over a shaft that would rotate and change contacts within the switch.
FOUND IT! It’s the neutral safety switch:
It looked like the old one was cracked. At least he said thank you.
