ok boys IM an old school wrench,I have a 73 type 1 v.w. I have been trying to get a brake pedal with poor results 2 masters the rears are adjusted properly & the L/rear brake hose has been replaced ( it was budging) Im using a mighty vac and even & 22 inchs vacumn I get little results,do you think this could be a residual check valve problem in the master even though by the looks of the adjusting rod its never been touched,when I crack the fitting at the master the vacumn goes away…god I hate V.W.s
Related topics
| Brakes, what have I overlooked? | 50 | 3342 | September 24, 2007 | |
| New Wilwood Disc Brakes Won't Release | 40 | 486 | June 30, 2025 | |
| Chevy van brakes | 2 | 391 | January 26, 2008 | |
| Brake problem (almost everything replaced still a soft pedal) | 44 | 86002 | September 18, 2019 | |
| '97 Taurus 3.0 OHV: Brake Piston Fell Out | 49 | 3795 | November 17, 2013 |
