what kind of work, pads, rotor, calipers… ? What were the conditions of the part(s) replaced?
OP said:
I wonder if these frequent replacements are from appointments during a yearly inspection or if the OP is taking the Outback in because something is wrong…
If not using the brakes enough makes them wear out faster, then mine should have been worn out 175,000 miles ago.
Be careful with this. Your brakes have ABS. Your engine braking does not.
Also the paddles don’t shift gears, they manipulate the CVT (if you have the 2.5 L 4 cylinder) to make it seem like it’s shifting gears. With the problems associated the CVTs I’d rather not stress it out any more than needed.
If you don’t use your brakes they’ll last a lifetime.
Plus, you’ll get unbelievable gas mileage.
