I am not getting any fluid to the rear brakes. When I loosen the lines at the abs modulator the 2 front seep fluid, the 2 rear do not, is the modulator shot or just the solenoids on top? 1994 olds cutlass supreme s 3.1, We just replace the entire back brake calipers and lines up to the the first unions we came to by the gas tank. And when we tried to bleed them nothing.
Related topics
| 1996 Chevrolet 2500 - no brake fluid to the rear | 4 | 1473 | August 19, 2019 | |
| No pressure to back drum brakes | 11 | 14398 | November 13, 2019 | |
| Brakes (FL) Won't Bleed after Repair | 24 | 10289 | March 31, 2018 | |
| Changed front calipers. Should I bleed back calipers also? | 11 | 865 | June 22, 2020 | |
| No brake pedal | 8 | 1219 | March 4, 2016 |
