I have a 1996 Chevy K1500 4x4 Z71 pickup. The wheel cylinder failed and the whole inside of the drum is coated in brake fluid and has been this way for many months. This is not a daily driver but only used to haul something, so it typically sits for a few weeks inbetween uses. I planned on replacing the wheel cylinder (obviously) brake pads and hardware kit. Do I need to replace the drum or can I just get them turned and clean them up a bit? They have .090" that can be turned off. I have access to a sand blaster to clean up the outsides.
Any insite would be helpful since I can’t seem to find an answer anywhere online.
