Let’s see…
“ATR-72” is a turborop commuter. “L-1011” is a tri-motor jet that hasn’t really been used since ETOPS (twin-jet flights allowed over the Atlantic).
“Deicing boots” are what they sound like: inflatable rubber boots on the leading edges of the wings. You inflate them to break off any ice that might be clinging to 'em.
“Known icing certification” means that the FAA says a plane is legal and safe to operate into clouds that have produced ice accumulation on other aircraft.
CA= Captain (pilot). FO=First officer (co-pilot).
GIGO is “garbage in, garbage out” and is a programmer’s term for getting worthless data from a program fed worthless inputs. (Often used in defense of a termed “computer error”: “it’s not the computer’s fault…GIGO…your data was worthless to begin with!”)
“Landing lights” are three green lights that illuminate when the gear is down and locked. There is also generally an “in transit” light, and some means of showing a fault. (A burnt-out light, BTW, is a very minor event…it happened to us, flying in to Atlantic City. We just told tower what was up, and that we’d need 5 minutes prior to landing to run some checklists. They said OK, but that they were going to scramble airport rescue regardless, on general principles.)
“altitude hold” is the portion of autopilot that holds (and captures) an altitude. Meaning, some of the AP can be on, without it all being on.
“pitot static system” are two sources of air pressure…the “static port” measures ambient pressure, and the “pitot tube” points directly forward so that it also measures the ram effect of the moving air. Together, they provide your data for airspeed, altitude, and rate of climb/descent. With them plugged, all of that data would be completely false!
“IMC” is “instrument meterological conditions,” which means you are in the clouds and cannot fly by reference to the outside horizon (you’d have no idea which way is up, which is what doomed that flight…visual flight would have given better references to replace the P/S stuff.)
“pitch and power setting” is where the nose is pointed, and how much power you’re giving her. If you “know your aircraft,” you should have a good idea what pitch she takes on climb out, at cruise, descent, and approach to landing…and where to set the thrust levers.
An “attitude indicator” is a gyroscopically-powered “artificial horizon” and is what you use in IMC to tell which way is up. They are probably visually familiar to the non-flying public…I’m sure Google links to a picture or two.
“IFR rating” is an additional endorsement that says you’re trained how to fly according to instrument flight rules, in IMC. The most basic license if VFR-only…meaning VMC.
“CFI” is certified flight instructor.
“CFM” is “Company Flight Manual” and is the system to which the company trains you and expects you to fly their equipment.
If I left anything out, somebody let me know…
Oh…and an “ILS” is a navigational beam that extends off the approach end of the runway, aligned with the runway (as much as possible) and on a 3-degree slope (as much as possible). In the airplane, there’s an instrument that looks like the crosshairs of a rifle scope…only the horizontal and vertical lines move. You correct towards the needle (i.e. fly to the right if the vertical needle is to the right of center)…so if the needles wind up centered like in a real rifle scope, you’re doing it just right.
