Best air filter brand (that is not a "performance")?
I have found sites where people prefer WIX, Fram, Napa Gold. I found this one post that suggests AC Delco is by far the best: http://forums.nicoclub.com/debunking-the-k-n-myth-why-oem-is-better-t180100.html But some people are saying that AC Delco is not as good now that Donaldson no longer makes them
I think that, as long as you avoid “white box” filters (no brand name displayed, and manufactured in China), you should be okay with any of the brands that you listed.
Any name brand. I use Fram.
Oh please, not another filter thread!!
I searched, VOLVO. There were threads talking about K & N vs. OEM. Couldn’t find anything brand specific for non-performance, and most were pretty old threads. I don’t get how it poses such a problem for you. It’s not as though my subject line was unclear
sometimes we forget that not everyone has talked these things to death. just us
@haul_stuff‌
If you want the best “non-performance” air filter, I suggest sticking to the factory part
It will fit correctly, and it won’t cause any problems
I’ve actually seen conditions where aftermarket non-performance filters were put together so shoddily, that they were causing a restriction. And the engine wasn’t breathing correctly, which cause the vacuum brake booster to not work correctly. Soon as I threw that junk out and sold the customer a factory air filter, all his problems were resolved
You are wise to stay away from K&N . . . there may be unintended consequences down the road
I’m with @texases here. I always use Fram if Wix is not available. Keep away from K&N because it’s way over-priced and could damage components of your engine.
Any aftermarket quality brand air filter will work just fine.
I worked in the filtration industry for over thirty years. And we would test major brand air filters to see how their performance compared to our air filters. The results showed there were subtle differences in filtration performance.
We also tested K&N air filters. These filters performed so poorly that the conclusion was made that if you want to keep birds and chipmunks out of your engine, that’s the filter to install.
And rabbits.
It’s human nature for people to convince themselves that their preferred brand is the best.
It’s the job of any marketing manager to convince the world that their company’s brand is the best.
Science tells a different story. Any brand name OEM-replacement filter will be designed to prevent the passage of particulates to well within the level necessary to protect your engine, and any brand name OEM-replacement filter should properly fit your car as long as it’s the correct one specified in the filter manufacturer’s catalog. Filter design and manufacture is not a “black art”. It’s straightforward and basic.
As VDC said, avoid fleamarket filters.
I also recommend avoiding oiled filter such as the K&N filters. They’re known to deposit oil on mas airflow (MAF) sensors, which, since the MAF is heated, cooks onto the surface and destroys the sensor.
Any brand name filter is fine. Air filters are not that complicated. I buy them online, usually when I am shopping for other parts or stuff, just to get the amazon free shipping. Keep it in the garage for when I need it.
Now oil filters are totally a different story :))
I used to be concerned about what viscosity and brand of oil to use in the oil bath air cleaner of the Lauson engine on the rototiller. The specifications called for 50 weight oil which was hard to find. When I learned a little more about engines, I found that any old oil worked just fine. My guess is today that any brand of air filter will work as well as any other brand.
As Tester said, any aftermarket quality filter will do.
Just change it as recommended in your owner’s manual.
Today’s engines don’t wear out due to intake filter issues.
Any new filter is better than a clogged old filter.
Visit any hot rod show and you’ll see lots of engines without any filter at all, just bug screens… many without even bug screens.
@‌Cavell
“Any new filter is better than a clogged old filter.”
I disagree
I’ve seen new filters that were constructed such that they were actually causing a problem. They had the correct dimensions and fit
But . . . Where the pleats were glued to the foam, so much glue was used, that the filter was causing a restriction
And it wasn’t super obvious at first . . . until you held the junky filter next to a new factory filter
In that case, NO filter is better than a restrictive white box filter
Then again, the MAF might not appreciate eating all that debris
Thank you all for your input. Much appreciated!
