What is the proper procedure to charge or jump a low battery with a POSITIVE GROUND?
Thank you.
Courtesy of Snap On Tools:
Positive Ground
? Connect negative charger cable clamp?black?to negative
battery terminal.
? Connect positive charger cable clamp?red?to vehicle
chassis, heavy gauge metal part of frame, or engine block
away from battery.
Do not connect the ground clamp to the carburetor, fuel
line or body sheet metal.
