Does brushing the posts on the car battery make it last longer?
nope…just insures you get good contacts…really no need to do them once cables are securely attached.
If you do it at home, it saves you from being stuck somewhere when it rains. If you park and listen to the stereofor fifteen minutes, you are more likely to be able to start the car later.
