B2600i '92 cab shifting problems
Shifting into gear was a problem occasionally, but lately, within 15 minutes of driving, I start feeling the shifting into higher or lower gear getting stiffer and will not shift into gear.
I’ve shared the problem with couple of my mechanics and it left them puzzled, since there are no leaks or low levels of fluid.
Please advise.
Thank you!
Have the Hydralic system for your clutch, bleed with new fresh fluid. You probably have moisture in there and as it’s heating up it’s giving you issues. Make sure to get all the old fluid out. Ps it should use regular brake fluid.
Thank you, gsragtop. Appreciate the advice!
