CarTalk.com Best of Deals Car Reviews Repair Shops Cars A-Z Radio Show
Auto and Roadway Redesign
At this time America is seeking massive public works projects with the potential to create large scale employment while returning universal and tangible benefits to all citizens. We also seek to find an alternative to the internal combustion engine and to end our dependence on gasoline to power automotive transportation.
Our infrastructure as a whole and our highways in particular are in need of repair and expansion to meet current and future demands. The best hopes for a practical alternative to the internal combustion engine are focused on the all electric vehicle.
The electric car has for decades awaited the invention of a low cost battery to provide the necessary mileage range for vehicles of a practical capacity and structure. We are still waiting.
To have an updated electric grid across this country which would allow the distribution of abundant electricity from multiple and efficient sources such as natural gas, nuclear, hydroelectric, wind solar and possibly some form of clean coal, is already universally recognized as an immediate necessity.
I contend that the technology to achieve all the goals enumerated above is readily at hand. The answer lays primarily in the revision and more extensive expansion our electric grid.
Not only must we expand the delivery and conveyance of electricity between all areas of the country but we should deliver eclectic power directly to battery driven vehicles while they travel our nation?s highways and wherever they may park ?at their home or at any public or private parking area.
In place of the elusive low cost, long range, automotive battery we have been unable to develop for decades, we can simply increase the availability of electric power to every highway and every parking area. It would then be possible to have adequately sized vehicles which can be used to commute daily or to drive non-stop across the entire country using presently affordable battery technology.
Direct powering of these all electric vehicles would be done while the car is on the highway. A trailing arm descending from the vehicle could make direct contact with the roadway or current could be transferred by electrical induction.
To limit innovation to the above revision would already achieve numerous goals, but should budgeting allow, at the same time that we electrify our highways we can also computerize our highway traffic movement.
Again the technology appears to be available. Drive your car onto the number one lane of the highway, input your destination, not only will electric power from the roadway power your car and charge your batteries but a computerized program will move your vehicle to the appropriate lane corresponding to your destination and control the movement and placement of your vehicle relative to all others.
Within a couple miles of your exit, your vehicle is returned to the number one lane, you are alerted, and when you signal, you again control driving as you exit on to surface streets.
Numerous benefits of this system allow far greater highway capacity, much improved safety, and an opportunity for all auto occupants to be at leisure or productive for extended trips.
As clarification it should be noted that the actual cost to build and maintain an electric vehicle, without the highly sophisticated and expensive battery system such as seen in the Telsa auto, is significantly less than the currently much more complex gasoline powered cars. Telsa does a fine job of explaining why their simple car with few moving parts must cost $109,000. It is the battery.
As electricity to both directly power and charge the batteries is provided to every highway and every parking area throughout the country, the electric bill to the vehicle owner will be made based on consumption. The car itself will be computerized and with each hook-up to the power grid it will give a cumulative report, allowing periodic billing.
In conclusion, I believe the above proposals represent the most practical solutions for auto and highway redesign. They are based on cost effective technology which is currently available.
References:
http://en....erless_car
http://en....e_charging
http://www.teslamotors.com/
