Hi everyone,
I’m having an issue with my 2019 Infiniti QX50. On hot days, the car noticeably loses power during acceleration — it feels like the turbo stops working properly. There’s no check engine light, but overall performance is clearly affected.
Has anyone else experienced something similar, especially in warm weather? Could this be related to heat soak or a known issue with the turbo or engine?
I see a few possibilities.
In very hot weather, the air contains a lower density of oxygen, and this results in a drop in power on all IC engines, whether they are turbocharged, or not. So, it’s possible that there is nothing wrong with the turbocharger.
Or, if there really is something wrong with the turbocharger, it would likely be due to lubrication issues. Are you changing the engine oil on schedule, in terms of both odometer mileage and elapsed time?
Are you using the correct specification full-synthetic 5w-30 oil?
Is the oil up to the correct level on the dipstick?
Ur car has VC motor. Very odd design. Easily could have issue with system as it’s very dependent on oil quality and pressure. If it runs “ok” otherwise I’d sell it.
