Are there portable trickle chargers that DON'T require a plug outlet?
I live in an apartment so I don’t have access to any outdoor plug outlets for plugging in a trickle charger. Nearly every car battery charger requires a plug outlet. I’ve had issues at times in the past with my car battery dying and would like to be better prepared especially as winter approaches in a few months. Not that it’s happened that frequently, but it’s severely annoying when it does happen.
Can anyone recommend one that has its own big battery to supply power from? It would be particularly nice if I could get a good one that trickle charges my battery from the cigarette lighter inside the car, so I could leave it locked in my car charging overnight.
Thank you!
Would it not make more sense to have the battery checked to see if it needs replaced ? A portable battery jump pack would be more useful. What you are talking about does not exist that I am aware of.
Some other posters on here have mentioned installing a small solar panel on their dashboard that they wire through a device that acts to trickle charge the battery. It wouldn’t be a bad idea to have your battery checked, though as @VOLVO_V70 mentions to make sure it still has sufficient charge and life to it. A portable jump pack would also probably be a simpler solution than setting up a solar panel.
Huh?
You want to use the power of your car’s battery to… charge the battery?
Or, did you mean that you would plug a trickle charger into the lighter outlet?
In any event, you can find battery-powered jump-starting devices and you may find it helpful to carry one of these in the car in case your battery goes dead.
Why would not that work?
Cordless battery trickle charger - might be possible if powered by Dilithium Crystals ( Star Trek ) . But then you might not need a battery.
Just get a portable battery jump starter like those shown here.
The best I can suggest is what is known as a jump-pack. It is a battery and a self contained charger that can be used to jump start your car. They have an on-board charger for the pack so you charge it in your apartment and carry it to your car for a jump. Most have a charge port (cigarette lighter socket) and a double ended cable that allows you to plug it into the car’s power port while it is running to charge the jump pack. When the car is not running, charge goes the other way if the battery is running down. They look like this;
But if your battery is going dead, find out why.
? The cigarette lighter gets its power from the battery, so this makes no sense.
I had good luck with a jump starter, a Schumacher XP400, until its battery failed after a couple of years. I kept it plugged in inside on a shelf out of the way.
The solar panel, a 1.5 watt unit from Harbor Freight, which should have produced more power than it loses when sitting around, did me no good at all. I can measure the current it produces (about 10 mA) and what my car uses (6 mA when off), so I don’t know why it didn’t help.
You may have a parasitic draw or a failing battery, either of which would be better to fix.
I replaced my car’s battery and just started it after 7 months sitting around in a minute.
My car battery is still fairly new, less than 2 years old. And I do already have a portable jump starter which often works, but not always. I want to stress as well that these are not frequent battery issues, just maybe a few times every few years. They’re just very annoying when they happen and I hate the feeling of powerlessness, being stranded, and of having to call and wait for help in case my portable jump starter does not work.
Getting a portable trickle charger and checking the battery regularly to make sure it is maintaining a healthy charge would make me feel much better.
I wouldn’t run out and buy a portable battery jump starter. I see that the car owner/operator draws attention to the approaching winter. Without knowing where the car is located and how cold it gets in the winter, a jump starter is possibly not a substitute for maintaining an adequate charge.
A discharged battery will freeze in areas of very cold winter weather and then will not take a charge or jump. In fact jump starting a frozen battery can cause an explosion. The battery will need to be thawed out before a starting attempt is made.
CSA
:palm_tree::sunglasses::palm_tree:
I found from testing that at least in my case, a 10W panel on the dash was necessary.
Sitting in bright sun all day the battery reaches 13.4V.
5W wasn’t enough to satisfy.
I’m a weekend driver and mostly short trips: an hour or less.
So I want to keep the battery full and happy.
A jump pack will help in a pinch, but it won’t prevent short battery life due to chronic undercharging.
No such thing. Only a solar powered one.
Hmmm… What’s the warranty? Mine came with an 8-year. What model is it?
Why not? You should get one that can charge from the cigarette lighter when the car is running if you’re worried about it not-starting when you’re out, and you should keep it charging inside when you’re home.
BTW, I buy the largest battery that will fit in the space I have, larger than the recommended model. I used to drive out into the wilderness for long times; didn’t want to get stranded. I’d listen to the radio in bad weather, read a book with my LED lamp.
Hi,
Have you found a solution to this? I am in a similar situation and do not have access to an outlet near my parking spot.
My car is notorious for draining battery bc the cooling system stays on for a little after turning off to cool the turbos. I also want to run my dashcam on continuous parking mode which will cobtantly draw a small amount of current. I have a solar panel that I will be installing in the fall, but I want to charge it fully first so the panel only has to maintain. I can remove & bring the battery home if need be but would like to avoid it.
I have a portable compressor/jumper with a 110v outlet. I have to check how many amps it can deliver and see what the trickle charger requirements are. That may be a solution if it all checks out.
Welcome to the forum, this is a 5yo thread and the OP has not been seen since
Sep 15, 2020, so he/she may not ever see this, and it was 7 years since they were even here before this time…
You may need a higher reserve rating battery or new battery depending, the battery should not be affected by the fans IF it was designed that way from the factory…
Best to describe your issue in detail and give us the year make and model, engine size and all the driveline info if it had options…
Also you may consider idling your engine for a few seconds (20-60) before turning off to cool everything down, turning the engine off when the turbo(s) are hot enough to run the battery down after turning off can cook the engine oil around the turbo bearings and cause damage down the road… And allowing the idling engine to cool everything down for a few seconds will/can keep the fans from having to run with the engine off saving the battery…
Think about what you are planning… You are charging a big battery with a smaller battery. Additionally, you are taking a 12v battery, using an invertor to make 110v AC, plugging in a trickle charger that takes that 110v AC to 12v DC. There are losses at each step. What you get out is much less than that little battery can provide. It will not work.
A remote charge needs to be from a generator. Or even one of those “solar generators” would work. And it will take hours. And you will likely want to watch those expensive devices to make sure they don’t disappear.
That sounds like the best answer. I use a “Battery Tender” 110v version, in this situation I’d pick one of their solar-powered models:
Amazon.com: Battery Tender 5 Watt Solar Panel 12V Battery Charger with Charge Controller - IP67 Weatherproof - Windshield or Handlebar Mountable - Included Ring Terminal Cable or OBD II Connector - 021-1172 : Automotive
Latest posted wants camera for security? And should have solar charger so thieves can steal that also? He mentions bringing battery into home each night? Now that’s a redneck move. Install battery everyday? Comical.
It mounts inside the windshield, at least.
