the heavily advertised aspect of Amsoil is the promise of longer oil change intervals.
it may be important to truckers with high oil volume in the system, but makes not much sense in the small engines.
you will not get any noticeable difference when using AMS and I would not recommend buying into their push of extended oil change intervals either
stick to what you can procure locally
