Replace mc & brake hose right front still getting air win bleed the right caliper fluid milked white could it be air getting in that caliper a lot pressure on that side. The other three wheels fluid run clear not a hole lot of pressure.
It’s difficult to understand your problem.
Are you saying that when you bleed the right caliper (which right caliper?) the fluid comes out the color of milk?
If the fluid isn’t clear, open the bleed valve until it does run clear. You won’t have to pump the brakes to do it. Then if you still have a spongy pedal, bleed the master cylinder with the left side of the truck jacked up a bit. When that dosn’t work, you should still have good enough brakes to drive it to the shop and they will finish it.
What is the best way to check the power booster
