Is there any common problems with this model’s A/C unit leaking? I am trying to save the money for a check at the shop for leaks if I know it is going to be to expensive to fix. Or is it fairly easy to fix?
It depends. Your best bet would be to take your vehicle in for a complete checkup at a good, independent AC specialist. They are the pros.
What model’s A/C unit?
‘‘This model’’…what model ?
PLUS
Why do you believe you need it checked ?
If you assume a leak…why ? is it not cold ?
Way back, my 92 Explorer a/c would leak down over the winter…two years in a row.
A charge up would last all summer with no problems but after the following winter it would be empty again.
The cold would contract the o-rings ever so slightly allowing seepage.
Not knowing exactly which was leaking, replacing all the o-rings after the second year solved the leak down forever.
Make, model, year, miles, symptoms?
