I have bled the front and rear while bleeding I didn’t seem to have much pressure. I bench bled the master cylinder and reinstalled and bled the system again. I still have very little brake pressure. Is it a bad master cylinder? Any help is appreciated
Probably a bad master cylinder. What is the year and milage of your civic?
2003 60,000 miles. When I bled the master cylinder on the bench it didn’t seem to offer much resistance. I haven’t done a master cylinder before
2003 CIVIC EX COUPE with ABS
BLEEDING SEQUENCE
Left Front
Right Front
Right Rear
Left Rear
SPECIAL PROCEDURES
Warning! Before bleeding the system, high pressure must be
released from the accumulator and power unit. A special
ALB-T wrench (Part No. 07HAA-SG00100) or equivalent
must be used to bleed the power unit valve under the red
cap. System pressures may be as much as 3000 PSI.
A face shield should be worn and the connections covered
with a rag when bleeding the system. Note: If ABS light
comes on and stays on, remove the 15 amp fuse to erase
codes and turn off light.
OEM Did Not Supply
AFTERMARKET APPROACH
OEM Did Not Supply
It’s also a manual with out abs
That would have been nice to know before asking others to help.
That’s why I added it.
