Proceed slowly and work it back and forth,sometimes you can find a device that screws in the sparkplug hole that will help break a piston free,but you may end up with a free piston and no compression,if that happens put some oil in the cylinder(hydraulic seal and you may get it to fire) if you get it to run a bit the compression may come up-Kevin
