Yes, fuse 10 in the interior drivers side fuse box for DRL control module, Headlight relay, AQS and ambient sensor, Left headlight leveling actuator and fuse 23 in the engine compartment fuse box for lo beams.
Try moving the wire bundle(s) coming out of the engine compartment junction box to see if the lights flicker. Sometimes this junction box has to be removed to reveal corroded connections underneath.
If you are certain you don’t have power to the bulb, but the ground at the bulb is ok, what you have to do is use the wiring schematic to trace the wiring backwards (i.e. towards the battery) and figure out where the problem is occurring.
The first check is whether you have battery voltage power output from the headlight relay when the low beams are switched on. Do you?
