Hi so I’m having a problem whenever I accelerate with the pedal to the floor I get high rpms but the car gains speed slowly. I don’t have any check engine light
Check the transmission fluid level. Continuing to drive a slipping transmission is a good way to fry it. If it is a newer vehicle, (you have not told us year mileage condition etc, ) you may not have a dipstick for transmission fluid. This will require a trip to a shop to check
If this truck has a manual transmission, then the symptoms indicate a badly-slipping clutch.
If it has an automatic trans, then there is slippage in the transmission.
