I read some of the past questions on this topic, but not sure where to start.
-AC blows warm air.
-AC light comes on as it should (green)
-Under-hood Fuses are fine
-Refilled Antifreeze a few days ago, but still blows warm.
-Turned on the AC, lifted the hood and did not see the two large fans blowing. (Not sure if that has to do with AC or just cooling the engine).
It could be just low on refrigerant, possibly due to a leak. An A/C shop could confirm both items. Unless you are planning to fix it yourself and you have the capability, you will likely have to take it to a shop eventually anyway.
My thoughts are either low refrigerant or you have a bad compressor. You could try refilling with refrigerant to see if that helps (they make some cans with a leak sealer in them to seal up any small leaks)- but this wouldn’t be a permanent fix. You’ll ultimately need to take it to a shop to see what the problem is. Good luck!
