… for the North Korean dictator…
I hadn’t previously been aware that Russia is making a Rolls-Royce wannabe.
Well Kim had better be wary of any gifts from the Russians. Does anyone remember the “New” US Embassy we were building Moscow in the late '80s? Under treaty we had to use Russina construction crews… The Russians stuffed it with so many bugging devices there was no way to remove all of them and the building was torn down and rebuilt…
In the New Building, the US Emblem built into the walls with carefully checked for bugs and none were found. But later they realized that the Russians were transmitting microwaves at the building and they found that a signal was being transmitted back out of the embassy when the Microwave were transmitted…
Further investigation found “inert” listening devices in the emblems that once they were hit with microwaves, the listening devices became active…
“Sneaky devils…”
So Kim, you are warned… That new car will probably be so full of listening devices that they can hear you “cut one…” or a Fail-Safe method of eliminating you if he should become a burden to Moscow…
Kim is one fearful individual and you should read about the Taeyangho Armoured Train that Kim travels on …
