97 RANGER EXTCAB 4 CYL 5 SPD—I have the PU, 2 cars, & a motorcycle. Only the pu has antilock brakes. #1 I don’t like them. #2 I can’t remember which one I am driving in an emergency, so I either lock the brakes or don’t push hard enough, either way at times, I don’t stop as well as I could. So, is there a way to “turn off” the antilock system so all vehicles (and stop) the same? Thx, SUG.
You should be able to locate either a fuse, or a relay, that you can pull out and that will disable the ABS. Don’t recommend it, but you can do it.
THX UNCLE TURBO–WITH THE ABOVE CIRCUMSTANCES IN MIND, WHY DO YOU NOT RECOMMEND IT? THX, SUG
