I smell antifreeze in the cab but see no noticeable leak. Since the core is so hard to change out should I try one of those “fix a leak” solutions in the radiator?
thanks
How can you be so sure it is the heater core?
I would check the oil first to see if it has any coolant in mixed with it.
