I just came here to add that a sensor can also cause intermittent stalling. I have a cam position sensor acting up and sometimes it stalls and runs rough at low speed/idle. Just throwing this into the mix for any DIY troubleshooters who may pass through here searching for an answer to their problems.
My car is a 97 Accord LX that is heavily modified electrically. I have removed the entire interior and cut out and patched up my wiring harness and lifted it behind the bar. So, may not be a 1 to 1 but I mostly just removed what i did not need/want and shortened what was needed and kept in tack. Cut out harness plugs a d a few relay or two.
Did you ever figure out the issue?
Welcome to the Car Talk…
This thread was started over 11 years ago so it is quite possible that the OP will not see your question, they were only on here for one day it looks like…
If you are having an issue that you would like help with please feel free to ask away…
Please give us all the vehicle information and what the symptoms are, with as much detail as possible…
