'95 Seville
My Caddie has only 105000 miles and looks great but has several performance issues. 1) The front end suspension is faulty; there’s a loud rattle and clang when I hit a bump and the nose appears very low.2) The upper half of the dash lights isn’t working. 3) Often, during start-up, the engine “backfires” under the hood. What needs to be done and what cost should I expect? Thanks.
  1. Have the front suspension inspected for a broken front stabilzer bar end link.
2} The dash may need new lamps installed or a new dash display.
  1. Check for a leaking fuel injector or fuel pressure regulator.
The cost depends on what is actually wrong.
