I have a 95 GMC Yukon 2 W D, 5.7 V8. The problem is that the engine has a misfire while idling. The RPM will drop some then come back up like it wants to die sometimes. As far as driving the vehicle it drives perfect, it only has a problem when it’s idling. It will idle fine for a few minutes then misfire a little bit. I have replaced the computer, distributor, plug wires, and plugs, as well as setting the timing back a little bit and it helped some but still has a little breakdown idling sometimes. Does anyone have ideas as to what else could be the problem? I think it’s the firing, not the idling as the problem. Thanks for any feedback.
Related topics
| 2200 RPM ~ 70-ish MPH | 1 | 556 | September 18, 2007 | |
| 2007 GMC Yukon - Idles rough - Backfires | 3 | 1376 | July 30, 2021 | |
| 2007 GMC Yukon rough idle | 0 | 694 | January 12, 2020 | |
| Intermittent miss/hesitation | 0 | 410 | October 24, 2011 | |
| Idles great but misses badly when accelerating | 3 | 534 | December 27, 2008 |
