My Ac Compressor and condensor are toast, when on the AC does not work, but it can cause my car to stall, or if turned on at highway speeds makes the var bog down. I was fine with not using the AC, but will need to defrost my windows this winter. Fog on the windshield is no fun. That aside, friend of mine saidbI could diaconnect a wire on the condensor to stop it from bogging down while driving and get heat on the windshield again. Can I do this? If so, is it the wire that plugs into the compressor?
Thanks for any help, can not afford the grand it will cost to repair at the moment.
