The shifter goes into the incorrect gear for what is showing on the dash.
For example:
A little left of Park = Park
Park=Reverse
Reverse/Neutral/Drive = Neutral
A little right (almost gear 2) of Drive = Drive
Once I have found the gear and the shifter is set, the handle has enough play in it that allows it to rest over the correct slot.
It started after I put the car into neutral from drive without pulling the handle back but instead just pushing it to the left. When I went to put it back into drive, it was still in neutral.
