i need help this car is overhiting and i have changed the water pump and tstat and i cannot find anything blocked. any ideas, please help
Are the radiator fans turning on? Get it warmed up and turn on the AC and the fans should turn on.
the fans do come on but the car has no water pump flow. the pump is new and the old pump had the same problem so it is not the pump. i had all the lines checked for any thing bloking it. the radiator is clean
Have you checked the thermostat and ruled out any other potential cause of overheating such as air pockets in the system, head gasket issues, etc?
