Hi all, I need some help diagnosing a car problem, then figuring out if I can do it myself or if I need help! Thanks in advance.
This 92 MB E300 has been sitting around for the better part of the last two years for various reasons (have another car with better mileage, don’t drive much anyways, no insurance on it, etc), and we’ve been trying to get it going again with some mixed luck. I just replaced one of the window regulators (cable busted) and the battery (alarm drained it dry), but now we’re having trouble starting it. It doesn’t happen every time, but when we try to start it, the starter motor seems to get going no problem and it turns pretty good, but it just won’t catch consistently. Its almost like there’s no fuel in there, or maybe no sparks or something? Sometimes it will catch for a second, but it takes a while. Usually once its going its good, but if we have to stop and wait at a red light, it will sometimes just die when shifting to drive (I usually put it in neutral and give some gas while waiting). Also sometimes just when its in a low gear and shifts up it will die too. Then, we have trouble starting it up again!
So whats going on, do you think? I was thinking maybe something along hte lines of fuel pump, spark plug, or injectors, but what do I know? (not much). Thanks for your help everyone!
Cheers,
Shane.
