92 Civic DX hatchback, non-Calif. AT
Power steering suddenly not working when cold (~20 oF) in AM; nearly impossible to turn the wheel (for my wife). When I get home from work, and it’s warmer (~30 oF), it works fine (for me). When it (mostly) behaves, it does drive fine (though I would say that the variable-assist PS is no longer as “tight” at high speeds as it once was, but the car’s nearly 20 years old!
This just began a week ago (live just north of New York city), and has now happened enough times that I believe her
So, since the PS fluid reservoir was just below lower line, I topped it up (Honda fluid!). No obvious leaks (I checked by putting some paper under the car, and watching for drips for a few days, including turning wheel from lock to lock over the paper).
Is it the pump? Or should I just flush the system (and how do you do that)?
Thanks!
