87 VW Vanagon engine problem
Hi,
I just replaced the cylinder gaskets on the 2.1 L water boxer engine (MV, digifant). I adjusted the valve lifters as recommended in the Bentley manual. However, the engine runs very roughly and turns off eventually. Can you recommend any other checks I can do my self? Can you recommend a repair shop in Miami Florida, that might be able to adjust my engine properly?
Thank you,
Carsten
I don’t have much to add other than the all the mechanics I know run screaming when a wasserboxer pulls into the lot
