car has new plugs wires ing module 3 new coils still has a miss on cylinder 5 where to i turn to next?
Run a compression test to see if this cylinder is lower on compression than rest of cylinders.
Should also have #5 fuel injector checked if equiped with them.
A compression test should always be the first step in diagnosing an engine performance problem; even if the engine only has 30k miles on it.
