VIN # 1N6SD16Y2RC358824 , MY TRUCK DOES NOT MOVE , IT GOES INTO ANY OF THE 5 SPEED MANUAL SHIFTER , THE GEARS GO IN VERY SMOOTH… BUT THE 2HIGH ON THE 4X4 SHIFTER DOES NOT ENGAGE , MOVE TO 4LO , 4HI AND NEUTRAL. I USED THIS TRUCK INSIDE MY PROPERTY IN THE WINTER , I HAVE SET OF FOUR SNOW CHAINS…I ALSO TRIED LOCKING AND UNLOCKING THE TWO FRONT TIRES WITH THE 4X4 KNOB/DIAL. thanks salvatore berlingieri holbrook ny 631-374-6232
Some 4x4s use vacuum to engauge transfer case, so maybe hose came off or split.
The VIN # means NOTHING to us. What is the Make/Model/Year???
I have a feeling its a 1994 nissan king cab pickup,but its just a suspicion
The OP may want to remove his phone number as well.
Yea…I saw his other post AFTER I responded to this one…But from THIS post there is no way of knowing what vehicle.
how can he remove his phone # you cant edit questions if you can will you let me know how i have a question i would like to edit but i cant seem to figure out how. i know how to edit replys to a question by clicking on the pencil in the bottom right hand corner but there is no pencil in the yellow box where the question is please help me figure this out thanks
