Seal wore out on right side, causing half shaft to seperate from spline, I replaced worn seal, reseated half shaft on spline, getting a grinding sound when it is in 2wd, when in 4wd high no grinding sound, is there a inner bearing that needs to be replaced
Related topics
| Ruined rear differential…how do I prevent this from happening again? | 37 | 11758 | September 28, 2021 | |
| Screwed up | 22 | 1831 | November 7, 2014 | |
| 4x4 growling noise | 1 | 562 | March 29, 2011 | |
| 4wd engagement and the front shaft of a toyota 4runner 1999 model | 4 | 1176 | May 24, 2014 | |
| 98 blazer won't engage into 4wd | 7 | 1392 | May 2, 2010 |
