2020 Chrysler 200 - Grinding in Engine
Still grinding in engine when trying to start car in early or late time dealer can find the problems
“dealer can find the problems”
That’s good, as a 2020 it must be under warranty.
it grinds when you try and start car? but motor is quiet or seems to run with no odd sounds after it is running?
grinds when motor turns over, is cranking, is trying to start. gotta be very picky on “when” the noise is present.
They stopped making Chrysler 200’s three or four years ago .
Well, it’s been over 24 hours. Apparently alex04 chooses not to respond.
No response seems to be the normal for about 75 % of those Ask Someone posts .
