Although very rare, I tend to agree with you on this one…
You had a pretty typical Hemi lifter failure happen… A failed lifter is a failed lifter… Redlining an engine while it’s in gear and actually being driven should, by design, be something the engine is capable of handling as long as there are not any underlying issues…
The MDS (Multi-Displacement System) lifters in modern Hemi engines have a known history of problems with the needle bearings in the roller, along with lubrication issues… Over time, the roller can develop excessive wear or seize, which then wipes out the camshaft lobe and destroys both components…
The lifter didn’t fail simply because you took the engine to redline… The factory redline isn’t the absolute mechanical limit of the engine; there is a safety margin built into that number… Could repeatedly taking it to redline shorten the life of a marginal lifter?? Sure… But if one trip to redline is enough to kill the lifter, I’d say that lifter was already on borrowed time… The failure was going to happen sooner rather than later anyway…
I’ve redlined pretty much every engine I’ve ever owned and never had an internal engine failure because of it… The one exception is my old Chevy truck — and I actually drive that one pretty easy because the transmission has a known weakness with the sun shell and/or input sprag failing during WOT upshifts… That’s a different kind of failure altogether…
