2019 Cadillac XT5 - Leaky rims
2019xt5 a w d platinum tires loose air because of aluminum rims need re sealed often only 4,000 miles on car anyone else having this problem paid a lot of money for this car and should not have to worry about putting air in tire every 3 to 4 days
Warranty problem, did the seal job work?
Common problem with alloy wheels.
How many times has it been to the dealer for this issue? You might end up needing to contact Cadillac using the procedure in your owner’s manual. (If you contact them in writing, it would be best if you looked up the difference between “loose” and “lose”.)
I’ve had alluminum wheels on the majority of my vehicles. I’ve never had to have them “re-sealed” and they didn’t leak. Who suggested that you need to have the wheels resealed every 4000 miles?
It was done at 4,000 miles and he is not confident that the problem is solved.
Are your rims chromed . . . ?
If so . . . did you pay to have them chromed after you bought the car new?
