2017 Lexus RX 350 - Transmission issues
How would i know if transmission
If transmission what?
Some Toyotas of that age had problematic transmissions, Toyota extended the warranty. Check with your dealership.
Purebred beat me to it… lol
You kinda cut the end off the sentence there… :wink:
With the limited info you gave I will leave this…
APPLICABLE WARRANTY
ď‚· This repair is covered under the Lexus Federal Emissions Warranty. This warranty is in effect
for 96 months or 80,000 miles, whichever occurs first, from the vehicle’s in-service date.
ď‚· Warranty application is limited to occurrence of the specified condition described in
this bulletin
MC-10166041-9999.pdf
I hear there are transmission shops out there that handle this kind of question every day.
Why are we speculating on an incomplete question?
Well clearly, because the transmission
…was a criminal?
It would be acting shifty…
The OP might be asking if using the paddle shifter hurts the transmission.
Who knows, we may never know…
I think it was “how would I know if transmission…” is complete?. And the answer is “no. Your transmission is incomplete.” It was cut off mid-sentence.
As a 2014 Toyota Highlander owner I’m also a member of a Highlander forum. The Lexus RX-350 is basically the same vehicle. Starting in 2017 with the introduction of the 8-speed transmission Toyota has had a slew of transmission failures. There have been a variety of class-action lawsuits already.
