2015 Nissan Frontier - Heat is weak
Heat don’t work if going down highway heat will come out but in city driving no heat just luke warm air.
I am guessing you are asking a question and not just letting us know.
check the coolant level when engine is cooled down. if it is low, you might have a leak that needs to be addressed. add coolant to proper level and have it checked out by a reliable mechanic. if it is at the proper level you might have air in the system that needs to be bled out.
now if you were just venting… then I am sorry to hear you are going to have a very cold winter driving.
Other possibilities are:
1: faulty thermostat
2: restricted heater core or
3: malfunctioning blend door or actuator
Thank you having it check out on Friday
Make sure the fan is running. Had not much cold air at stop lights, but fine on the highway. Turned out the fan was not working and a replacement variable resister fixed it.
