2014 Ford Transit Connect - Failing Power Steering
power stering loses power some times while driving
Could be a slipping serpentine belt, failing pump or failing rack.
Thank you will check those things out
Check the battery and charging system, if the battery voltage drops to a critical level the electric power steering may shut down.
