I have a 2014 Cadilac XTS V sport
My left brake light went out .
I took it to the dealer and they said they would have to change the whole tail light assembly at a cost of $870.00
After a veterans discount.
??? Doesn’t sound right to me, what say you .
What does the diagnosis say is the problem?
Is it possible it is just the bulb or socket?
Try an independent mechanic, I don’t understand why the entire assembly needs to be changed.
LED tail lights don’t have light bulbs.
So diodes can’t have a break in the wire lieads?
Agree a 7 year old car does not need to go to the dealer an independent mechanic should be much cheaper.
An open circuit in the diodes or circuit board is the likely cause of failure, in that case the price will be $870.
It’s a nice car. It’s not a neon. Expensive parts.
Did you not notice that the reviews said it did not come with the LED lights ?
no, sorry. lack of sleep is hitting me LOL
WW , that part seems to have the same problem as the other one you posted . Apparently the rear lense has a LED light but there is a separate module that has the brake and backup lights.
OK I give. its not my day today. I am having brain farts today. LOL
I am so thinking going into led replacement and repair could be a lucrative business
Not disagreeing, but I found a flexible tail-light circuit board laying in the road one time, likely result from car accident. Everything on it, including the LED’s are surface mounted, and repairing something like that reliably, well, it wouldn’t be a simple job. OP has this problem resolved presumably, but for those looking for a less expensive LED tail-light fix, best bet is to ask shop to verify by probing that the appropriate input voltage is reaching the circuit board. After that, a used replacement unit from a wreck.
