can looses power when climbing a hill
Other ideas
- engine compression
- engine was overheating (did engine seem to be misfiring, sort of like a hick-up?)
- if vehicle slowed down but engine rpm speeded up, transmission may be slipping
The Accent was an under powered, entry level car even when new.
A blockage in the exhaust is another possibility to add to the list (assuming the transmission isn’t slipping as George_San_Jose1 wonders).
My son owns a 2015 Accent. It has plenty of pep. Far more pep then my 1974 Vega.
Start with the simplest thing: is the air filter clogged?
Is there a check engine light on?
How many miles on the vehicle?
were the plugs ever changed?
Was the air filter ever changed?
Have you even driven a 2015 Accent ? They had about average performance and were not underpowered at all . Just to many people think the vehicle has to do 0 to 60 in 5 seconds .
