2013 Dodge Dart - Battery drain
Thank you for the response. Everything is factory. No corrosion on posts or cables. So I guess I am left with faulty charging, a bad alternator, worn tensioners or loose belts. Will let you know the results from the dealership.
Sitting idle for a week and the car would not start still makes me think of a parasitic drain though.
