2011 Chevrolet 1500 - nothing happens when I turn the key
turn the key to start but nothing happens,lights come on but will not start,can turn the key many times and might turn over, it might stay running
Likely battery is weak or battery connections corroded, or both.
Try shifting the transmission into neutral and then see if it starts.
If it does, there’s a problem with the park/neutral safety switch.
I keep forgetting about the neutral safety switch.
