vibration noise on passenger side front
we are going to need a little more info.
does it happen all the time or sometimes?
inside the car or outside?
when at idle standing still or when driving?
If when driving, at what speed? and is it constant?
the more info you can give, the better we can help you.
Try rotating the tires. Does the noise/vibration move to the rear? If so, then tires/wheels are the problem. If not, then likely a drivetrain issue. I’m betting on drivetrain.
