Does anyone else have problem with the ABS on the front of their 2010 GMC terrain on the right side replaced the pigtail and the sensor and it’s still coming up that it’s not working on the left side I just noticed it’s not working now and the bearing checks out OK or the sense I checked it with their own metre and it worked fine.
Welcome to Car Talk as you have been redirected here…
The 1st thing I recommend you doing is using some punctuation in your sentence as it is kind of hard to follow, and probably why no responses yet…
Have you checked the codes, if so post them here, if not go to your local auto parts store, as most will do it for free, then post them here…
You may need to use a good scanner in order to watch Live data for the wheel speed sensors to see what they are doing…
