2010 Dodge Avenger tire sensor won't shut off
Put new tire sensor still light is still on?
You have 4 sensors and maybe 5 - one for the spare. Maybe another one has failed?
Did you install a cloneable aftermarket sensor and assign the old numbers to the new sensor?
Did you install a new sensor with different numbers . . . if so, did you perform the relearn procedure?
Tire pressures correct?
